소개
The display is incorporated into the Lid of the laptop and is susceptible to cracking from falls or pressure. Often this could result in the laptop being unusable. This guide will show you how to disconnect and remove the Lid from the main laptop body, separate the LCD from the lid.
필요한 것
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Remove the black and white wires. they simply lift off the posts.
Remove the cable attaching the LCD to the motherboard, on the left side of the laptop.
