주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4284 RAM Replacement
필요한 것
  1. Toshiba Satellite A105-S4284 RAM Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A105-S4284 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 RAM Replacement, RAM: 2 단계, 이미지 1/2 Toshiba Satellite A105-S4284 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite A105-S4284 RAM Replacement: 3 단계, 이미지 2/2
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 RAM Replacement: 4 단계, 이미지 1/3 Toshiba Satellite A105-S4284 RAM Replacement: 4 단계, 이미지 2/3 Toshiba Satellite A105-S4284 RAM Replacement: 4 단계, 이미지 3/3
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
pfedigan
회원 가입일: 04/12/13
11 평판
안내서 4개 작성하였습니다
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 회원
CPSU-MANESS-S13S2G23
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 18
전체 시간: 2,056
