주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba Satellite A205-S4577 Fan Replacement
필요한 것
  1. Toshiba Satellite A205-S4577 Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Fan Replacement, Speaker Cover: 3 단계, 이미지 3개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement, Speaker Cover: 3 단계, 이미지 3개 중 2개 Toshiba Satellite A205-S4577 Fan Replacement, Speaker Cover: 3 단계, 이미지 3개 중 3개
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Fan Replacement: 4 단계, 이미지 1개 중 1개
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 Fan Replacement, Keyboard: 6 단계, 이미지 1개 중 1개
    • Remove the two 4mm flat-head screws indicated in the photo.
  7. Toshiba Satellite A205-S4577 Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
    • When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
  8. Toshiba Satellite A205-S4577 Fan Replacement: 8 단계, 이미지 1개 중 1개
    • The Ribbon Cable must be disconnected here to release the keyboard.
    • Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
    • When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
    • You can now lift and remove the keyboard.
  9. Toshiba Satellite A205-S4577 Fan Replacement, Monitor: 9 단계, 이미지 3개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement, Monitor: 9 단계, 이미지 3개 중 2개 Toshiba Satellite A205-S4577 Fan Replacement, Monitor: 9 단계, 이미지 3개 중 3개
    • Locate the gray wire on the right.
    • Detach the white end by gently pulling each socket away from the other.
  10. Toshiba Satellite A205-S4577 Fan Replacement: 10 단계, 이미지 2개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement: 10 단계, 이미지 2개 중 2개
    • On the left, locate the black and white wires with gold tips on the end.
    • Pull up on the wires to detach them.
  11. Toshiba Satellite A205-S4577 Fan Replacement: 11 단계, 이미지 3개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement: 11 단계, 이미지 3개 중 2개 Toshiba Satellite A205-S4577 Fan Replacement: 11 단계, 이미지 3개 중 3개
    • Locate the thick tan cord on the left.
    • Slide the tan cord as shown to detach it.
  12. Toshiba Satellite A205-S4577 Fan Replacement: 12 단계, 이미지 2개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement: 12 단계, 이미지 2개 중 2개
    • On the right, locate the thick black wire with the white rectangular end.
    • Pull up on it to detach it.
  13. Toshiba Satellite A205-S4577 Fan Replacement: 13 단계, 이미지 3개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement: 13 단계, 이미지 3개 중 2개 Toshiba Satellite A205-S4577 Fan Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver.
  14. Toshiba Satellite A205-S4577 Fan Replacement: 14 단계, 이미지 1개 중 1개
    • Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
  15. Toshiba Satellite A205-S4577 Fan Replacement, Front Cover: 15 단계, 이미지 1개 중 1개
    • Locate the screws that are shown in the image.
    • Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
  16. Toshiba Satellite A205-S4577 Fan Replacement: 16 단계, 이미지 2개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement: 16 단계, 이미지 2개 중 2개
    • Lift up on the front cover to remove it.
  17. Toshiba Satellite A205-S4577 Fan Replacement, Fan: 17 단계, 이미지 1개 중 1개
    • Locate the 6mm flat-head screw in the top right corner of the bottom of the laptop.
    • Remove this screw with the Phillips 00 Screwdriver.
  18. Toshiba Satellite A205-S4577 Fan Replacement: 18 단계, 이미지 3개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement: 18 단계, 이미지 3개 중 2개 Toshiba Satellite A205-S4577 Fan Replacement: 18 단계, 이미지 3개 중 3개
    • Locate and remove the white connector that is .75 inches wide.
  19. Toshiba Satellite A205-S4577 Fan Replacement: 19 단계, 이미지 3개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement: 19 단계, 이미지 3개 중 2개 Toshiba Satellite A205-S4577 Fan Replacement: 19 단계, 이미지 3개 중 3개
    • Locate and remove the smaller white connector (far right) and any tape that is holding it down.
  20. Toshiba Satellite A205-S4577 Fan Replacement: 20 단계, 이미지 3개 중 1개 Toshiba Satellite A205-S4577 Fan Replacement: 20 단계, 이미지 3개 중 2개 Toshiba Satellite A205-S4577 Fan Replacement: 20 단계, 이미지 3개 중 3개
    • Remove any tape that is still covering the fan.
    • Remove the fan.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Cameron Howard
회원 가입일: 04/16/13
62 평판
안내서 3개를 작성함
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 회원
CPSU-REGAN-S13S17G6
5 회원들
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 16
지난 30일: 36
전체 시간: 1,873
