주요 콘텐츠로 건너뛰기
Toshiba Satellite A205-S4577 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite A205-S4577 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Locate the hard drive cover on the bottom, left-hand corner of your laptop.
    • Using a Phillips #00 screwdriver, remove both 4mm screws.
  2. Toshiba Satellite A205-S4577 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Lift the cover to reveal the old hard drive.
    • Carefully detach the hard drive from the SATA/Power connector.
  3. Toshiba Satellite A205-S4577 Hard Drive Replacement: 3 단계, 이미지 1/1
    • After removing the old hard drive, place the new hard drive into the bay, and firmly reattach it to the SATA/Power connector.
결론
Daniel Johnson
회원 가입일: 04/07/13
108 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 회원
CPSU-REGAN-S13S17G6
5 회원들
안내서 33개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 2,392
