주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba Satellite A205-S4577 Keyboard Replacement
필요한 것
  1. Toshiba Satellite A205-S4577 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Keyboard Replacement, Speaker Cover: 3 단계, 이미지 3개 중 1개 Toshiba Satellite A205-S4577 Keyboard Replacement, Speaker Cover: 3 단계, 이미지 3개 중 2개 Toshiba Satellite A205-S4577 Keyboard Replacement, Speaker Cover: 3 단계, 이미지 3개 중 3개
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 Keyboard Replacement, Keyboard: 6 단계, 이미지 1개 중 1개
    • Remove the two 4mm flat-head screws indicated in the photo.
  7. Toshiba Satellite A205-S4577 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
    • When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
  8. Toshiba Satellite A205-S4577 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • The Ribbon Cable must be disconnected here to release the keyboard.
    • Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
    • When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
    • You can now lift and remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Daniel Johnson
회원 가입일: 04/07/13
111 평판
안내서 4개를 작성함
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 회원
CPSU-REGAN-S13S17G6
5 회원들
안내서 33개를 작성함
3가이드 댓글
When I got to step 8 in removing the keyboard, the green ribbon cable is connected to a white pin connector. The while pin connector came off. How can I reconnect it?
Thanks
Dave
dave@mediabistro.com
dave argie - 답글 공유
Is it the actual cable connection or the push tab that holds the flex cable in place?
South30 - 공유
Hi Judson
It is the actual connection that appears as white in the picture. It came off.
Thx
Dave
dave arganbright - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 41
전체 시간: 2,337
