주요 콘텐츠로 건너뛰기
Toshiba Satellite A205-S4577 RAM Replacement
필요한 것
  1. Toshiba Satellite A205-S4577 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Identify the rectangular plastic RAM cover located in the bottom part of your laptop.
    • Remove the 4mm flat-head screws on the RAM cover.
    • Use a plastic opening tool to pry the RAM cover upward.
  2. Toshiba Satellite A205-S4577 RAM Replacement: 2 단계, 이미지 1/1
    • Remove the RAM cover.
  3. Toshiba Satellite A205-S4577 RAM Replacement: 3 단계, 이미지 1/1
    • Press the two tabs on the side of the PC2-5300 2 GB RAM Chip to unlatch it.
    • To remove the PC2-5300 2 GB RAM Chip, pull it out at a slightly upward angle.
  4. Toshiba Satellite A205-S4577 RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite A205-S4577 RAM Replacement: 4 단계, 이미지 2/2
    • To replace the ram, insert the new PC2-5300 1 GB RAM Chip you have gathered back into the laptop.
    • Make sure the notch in the middle of the stick is lined up correctly and push firmly into place.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the laptop. Repeat process for additional RAM sticks.
  5. Toshiba Satellite A205-S4577 RAM Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A205-S4577 RAM Replacement: 5 단계, 이미지 2/2
    • To replace the ram, insert the new RAM sticks you have back into the computer.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the computer. Repeat process for additional RAM sticks.
  6. Toshiba Satellite A205-S4577 RAM Replacement: 6 단계, 이미지 1/1
    • Screw the back plate of the RAM back onto the device.
결승점
Daniel Johnson
회원 가입일: 04/07/13
108 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 회원
CPSU-REGAN-S13S17G6
5 회원들
안내서 33개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,382
