주요 콘텐츠로 건너뛰기
Toshiba Satellite A205-S4577 USB 3.0 ports Replacement
필요한 것
  1. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 2 단계, 이미지 1/1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: 3 단계, 이미지 1/3 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: 3 단계, 이미지 2/3 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: 3 단계, 이미지 3/3
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 4 단계, 이미지 1/1
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 5 단계, 이미지 1/1
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Front Cover: 6 단계, 이미지 1/1
    • Locate the screws that are shown in the image.
    • Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
  7. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 7 단계, 이미지 1/2 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 7 단계, 이미지 2/2
    • Lift up on the front cover to remove it.
  8. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, USB 2.0 Ports: 8 단계, 이미지 1/1
    • Locate the USB 2.0 cable on the bottom right corner of the laptop.
  9. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 9 단계, 이미지 1/2 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 9 단계, 이미지 2/2
    • Locate the white slot on the left side of the USB 2.0 wire.
    • Carefully detach the wire by pulling the cable to the right of the slot.
결론
Curtis
회원 가입일: 04/18/13
103 평판
안내서 1개 작성함
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 회원
CPSU-REGAN-S13S17G6
5 회원들
안내서 33개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 21
전체 시간: 1,802
