주요 콘텐츠로 건너뛰기
Toshiba Satellite A205-S5812 DVD Drive Replacement
필요한 것
  1. Toshiba Satellite A205-S5812 DVD Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 DVD Drive Replacement: 2 단계, 이미지 1/1
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 DVD Drive Replacement: 3 단계, 이미지 1/1
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
  4. Toshiba Satellite A205-S5812 DVD Drive Replacement, DVD Drive: 4 단계, 이미지 1/1
    • Remove the 3mm screw using a Phillips #00 screwdriver located beneath the RAM module cover. This screw holds the DVD drive in place.
  5. Toshiba Satellite A205-S5812 DVD Drive Replacement: 5 단계, 이미지 1/1
    • Carefully slide the DVD drive out of the side of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Harms
회원 가입일: 04/03/19
232 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 326
