주요 콘텐츠로 건너뛰기
Toshiba Satellite A205-S5812 RAM Module Replacement
필요한 것
  1. Toshiba Satellite A205-S5812 RAM Module Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 RAM Module Replacement: 2 단계, 이미지 1/1
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 RAM Module Replacement: 3 단계, 이미지 1/1
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
  4. Toshiba Satellite A205-S5812 RAM Module Replacement, RAM Module: 4 단계, 이미지 1/1
    • Remove the two 3mm Phillips #00 screws holding the plastic cover over the RAM modules.
  5. Toshiba Satellite A205-S5812 RAM Module Replacement: 5 단계, 이미지 1/1
    • Gently lift the plastic cover. Once the plastic cover is removed, the two RAM cards will be visible.
  6. Toshiba Satellite A205-S5812 RAM Module Replacement: 6 단계, 이미지 1/2 Toshiba Satellite A205-S5812 RAM Module Replacement: 6 단계, 이미지 2/2
    • Press the silver tabs away from the RAM stick to remove it. Both RAM modules can be removed using this technique.
    • Do not touch the gold strip on the RAM card because the oils on your fingers can potentially cause damage to the module.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Harms
회원 가입일: 04/03/19
232 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 220
