주요 콘텐츠로 건너뛰기
Toshiba Satellite A205-S5812 WiFi Card Replacement
필요한 것
  1. Toshiba Satellite A205-S5812 WiFi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 WiFi Card Replacement: 2 단계, 이미지 1/1
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 WiFi Card Replacement: 3 단계, 이미지 1/1
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
  4. Toshiba Satellite A205-S5812 WiFi Card Replacement, WiFi Card: 4 단계, 이미지 1/1
    • Remove all the 3mm long screws on the underside of the laptop.
  5. Toshiba Satellite A205-S5812 WiFi Card Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A205-S5812 WiFi Card Replacement: 5 단계, 이미지 2/2
    • Remove the black plastic bezel above the keyboard by prying upwards with a flat object.
  6. Toshiba Satellite A205-S5812 WiFi Card Replacement: 6 단계, 이미지 1/1
    • Remove the two Phillips #00 2mm long screws located under the bezel that hold the keyboard to the chassis.
  7. Toshiba Satellite A205-S5812 WiFi Card Replacement: 7 단계, 이미지 1/2 Toshiba Satellite A205-S5812 WiFi Card Replacement: 7 단계, 이미지 2/2
    • Lift the top of the keyboard and press the pins retaining the keyboard ribbon cable towards the screen with a rubber spudger to release the keyboard from the laptop. Set the keyboard aside.
  8. Toshiba Satellite A205-S5812 WiFi Card Replacement: 8 단계, 이미지 1/3 Toshiba Satellite A205-S5812 WiFi Card Replacement: 8 단계, 이미지 2/3 Toshiba Satellite A205-S5812 WiFi Card Replacement: 8 단계, 이미지 3/3
    • After removing the keyboard, gently pry upwards on the gold contacts holding the white and black WiFi antennae wires using a rubber spudger to release them from the card. Then, simply pull upwards and out to remove the card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kenneth Tynan
회원 가입일: 04/03/19
318 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 36
전체 시간: 1,005
