주요 콘텐츠로 건너뛰기
Toshiba Satellite A210 Keyboard Replacement
필요한 것
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A210 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A210 Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: 4 단계, 이미지 1/3 Toshiba Satellite A210 Keyboard Replacement: 4 단계, 이미지 2/3 Toshiba Satellite A210 Keyboard Replacement: 4 단계, 이미지 3/3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A210 Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: 6 단계, 이미지 1/1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Youlen
회원 가입일: 04/11/13
40 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-5, Regan Spring 2013 Cal Poly, Team 17-5, Regan Spring 2013 회원
CPSU-REGAN-S13S17G5
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
very useful. THANKS
ANDREAS - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 21
전체 시간: 2,604
