주요 콘텐츠로 건너뛰기
Toshiba Satellite A210 Optical Disc Drive Replacement
필요한 것
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A210 Optical Disc Drive Replacement: 2 단계, 이미지 2/2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: 3 단계, 이미지 1/2 Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: 3 단계, 이미지 2/2
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: 4 단계, 이미지 1/3 Toshiba Satellite A210 Optical Disc Drive Replacement: 4 단계, 이미지 2/3 Toshiba Satellite A210 Optical Disc Drive Replacement: 4 단계, 이미지 3/3
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: 5 단계, 이미지 1/3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: 5 단계, 이미지 2/3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: 5 단계, 이미지 3/3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bret Wilson
회원 가입일: 04/11/13
274 평판
안내서 1개 작성함
Cal Poly, Team 17-5, Regan Spring 2013 Cal Poly, Team 17-5, Regan Spring 2013 회원
CPSU-REGAN-S13S17G5
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Question : if i this will my screen start working ng again
jessica johnson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,602
