소개
Replacing a hard drive is a great yet simple fix. Make sure your new drive is the 2.5" laptop hard drive!
필요한 것
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
Find the battery compartment.
Slide the left slider which is just beneath the battery compartment into its leftmost position.
Locate the hard drive in the left hand corner, and remove the two 4mm Phillips #1 screws.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 2개
What if I don't have the metal housing
I bought the laptop from someone and it didn't have the metal housing and the laptop just keeps going from startup screen to loading back and fourth can someone help
