주요 콘텐츠로 건너뛰기
Toshiba Satellite A215 S4697 Latch Replacement
필요한 것
  1. Toshiba Satellite A215 S4697 Latch Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 Toshiba Satellite A215 S4697 Latch Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Place laptop right side up on a flat and clean surface. Open the laptop.
    • Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys.
    • Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
  2. Toshiba Satellite A215 S4697 Latch Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the two 2.3mm Phillips #1 screws at the top of the keyboard that attaches the keyboard to the frame behind it.
    • Remove screws.
  3. Toshiba Satellite A215 S4697 Latch Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite A215 S4697 Latch Replacement: 3 단계, 이미지 3개 중 3개
    • Find the latch above the F8 key that overlaps the keyboard.
    • Use a plastic opening tool to press the key board's tab downward, until the key board is released.
  4. Toshiba Satellite A215 S4697 Latch Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the keyboard out by shifting it forward towards the screen and pulling up.
    • CAUTION: Do not pull it out all the way yet. It is still attached to the laptop by a cable.
  5. Toshiba Satellite A215 S4697 Latch Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Satellite A215 S4697 Latch Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable.
    • Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily.
    • Pull out the cable and completely remove the keyboard.
  6. Toshiba Satellite A215 S4697 Latch Replacement, 15.4" WXGA TruBrite LCD Screen: 6 단계, 이미지 3개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement, 15.4" WXGA TruBrite LCD Screen: 6 단계, 이미지 3개 중 2개 Toshiba Satellite A215 S4697 Latch Replacement, 15.4" WXGA TruBrite LCD Screen: 6 단계, 이미지 3개 중 3개
    • Begin by carefully removing the rubber bumper pads located at each corner of the plastic screen casing.
    • Using a Phillips screwdriver you may unscrew and remove the screws located directly under the the rubber bumper pads. Remember to keep track of the removed screws!
  7. Toshiba Satellite A215 S4697 Latch Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Satellite A215 S4697 Latch Replacement: 7 단계, 이미지 3개 중 3개
    • Once the screws are removed using a plastic opening tool gently pry the plastic screen casing apart.
    • Next, carefully pry the screen casing from the monitor's hinge to remove the plastic casing.
    • Last, locate the (6) six screws located on either side of the compuet screen and remove.
  8. Toshiba Satellite A215 S4697 Latch Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Gently place screen face down on laptops hardware
    • Detach tape that is over the screens connection to the laptop, and detach connection with tweezers by pulling back
    • Disconnect blue wire near the base of the screen with tweezers, by pulling it straight out
  9. Toshiba Satellite A215 S4697 Latch Replacement, Latch: 9 단계, 이미지 2개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement, Latch: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Refer to Toshiba Satellite screen replacement guide to remove screens outer shell.
    • Next remove the latch with a set of tweezers by gently squeezing the back of the latch to free it from the outer casing.
  10. Toshiba Satellite A215 S4697 Latch Replacement: 10 단계, 이미지 3개 중 1개 Toshiba Satellite A215 S4697 Latch Replacement: 10 단계, 이미지 3개 중 2개 Toshiba Satellite A215 S4697 Latch Replacement: 10 단계, 이미지 3개 중 3개
    • Locate the spring on the inside edge of the casing. It is located on the top left side of the screen casing and is connected to the latch arm.
    • Remove the spring by carefully pulling it off of the latch arm. Be careful not to lose the spring!
    • Now you can remove the latch arm by sliding it to the left and popping in out of place.
  11. Toshiba Satellite A215 S4697 Latch Replacement: 11 단계, 이미지 1개 중 1개
    • Then connect the latch hook to the latch arm, and test it to make sure it slides over and back into place.
결론
작성자
4다른 기여자 명과 함께
Tyler
회원 가입일: 03/12/14
1 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 892
