주요 콘텐츠로 건너뛰기
Toshiba Satellite A215 S4697 Optical Drive Replacement
필요한 것
  1. Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Optical Drive Replacement: 2 단계, 이미지 1/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 2 단계, 이미지 2/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 2 단계, 이미지 3/3
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 2/3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3/3
    • Turn computer over so that the battery compartment is facing up and is at the top.
    • Locate and unscrew one captive Phillips #1 screw located at the center.
    • A captive screw cannot be completely removed from the device's component.
  4. Toshiba Satellite A215 S4697 Optical Drive Replacement: 4 단계, 이미지 1/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 4 단계, 이미지 2/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool to open the motherboard access cover.
    • Do not touch the motherboard.
  5. Toshiba Satellite A215 S4697 Optical Drive Replacement: 5 단계, 이미지 1/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 5 단계, 이미지 2/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 5 단계, 이미지 3/3
    • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
  6. Toshiba Satellite A215 S4697 Optical Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite A215 S4697 Optical Drive Replacement: 6 단계, 이미지 2/2
    • Flip your device right side up, and rotate it so that the optical drive is facing you.
    • Insert a paper clip into a manual release switch located to the right of the automatic release button.
    • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
  7. Toshiba Satellite A215 S4697 Optical Drive Replacement: 7 단계, 이미지 1/2 Toshiba Satellite A215 S4697 Optical Drive Replacement: 7 단계, 이미지 2/2
    • Gently pull out the disk drive until you can see the metallic case of the optical drive.
    • Hold the metal case and continue to pull the drive out toward you.
  8. Toshiba Satellite A215 S4697 Optical Drive Replacement: 8 단계, 이미지 1/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 8 단계, 이미지 2/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 8 단계, 이미지 3/3
    • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
  9. Toshiba Satellite A215 S4697 Optical Drive Replacement: 9 단계, 이미지 1/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 9 단계, 이미지 2/3 Toshiba Satellite A215 S4697 Optical Drive Replacement: 9 단계, 이미지 3/3
    • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Mike Dongyub Ryu
회원 가입일: 04/16/13
566 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-12, Maness Spring 2013 Cal Poly, Team 4-12, Maness Spring 2013 회원
CPSU-MANESS-S13S4G12
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 4,356
