주요 콘텐츠로 건너뛰기
Toshiba Satellite A215 S4697 RAM Replacement
필요한 것
  1. Toshiba Satellite A215 S4697 RAM Replacement, RAM: 1 단계, 이미지 1/3 Toshiba Satellite A215 S4697 RAM Replacement, RAM: 1 단계, 이미지 2/3 Toshiba Satellite A215 S4697 RAM Replacement, RAM: 1 단계, 이미지 3/3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is away from you.
    • Unscrew the two captive screws with the Phillips #1 and open the compartment.
    • The captive screws cannot be removed from the lid.
  2. Toshiba Satellite A215 S4697 RAM Replacement: 2 단계, 이미지 1/3 Toshiba Satellite A215 S4697 RAM Replacement: 2 단계, 이미지 2/3 Toshiba Satellite A215 S4697 RAM Replacement: 2 단계, 이미지 3/3
    • Pull the two tabs away from the RAM so that the RAM will be removable.
    • Make sure to gently pull the RAM away from the base connections in the device. Do not use excessive force or other tools to remove it.
  3. Toshiba Satellite A215 S4697 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite A215 S4697 RAM Replacement: 3 단계, 이미지 2/2
    • After the old RAM has been removed, insert the new RAM stick and ensure that they are oriented in the correct direction before installation. This can be done by lining up the gold connections to each other.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Nikhitha Byragani
회원 가입일: 04/16/13
58 평판
안내서 1개 작성함
Cal Poly, Team 4-12, Maness Spring 2013 Cal Poly, Team 4-12, Maness Spring 2013 회원
CPSU-MANESS-S13S4G12
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
ned solution for my satitillate pro as the fix i need is not listed . my Toshiba is a l875d-s7332 and cu
ls not find the right as the fix given is for and older moldel, can i pls get the right data mailed to my email asasp pls
wendell burgess - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 2,786
