소개
Installing the RAM is a quick and easy process, just make sure you have the appropriate RAM for your laptop. The Toshiba Satellite A215 S4697 has a max of 4GB of RAM. This means two 2GB of RAM cards.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
ned solution for my satitillate pro as the fix i need is not listed . my Toshiba is a l875d-s7332 and cu
ls not find the right as the fix given is for and older moldel, can i pls get the right data mailed to my email asasp pls
