주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Installing the RAM is a quick and easy process, just make sure you have the appropriate RAM for your laptop. The Toshiba Satellite A215 S4697 has a max of 4GB of RAM. This means two 2GB of RAM cards.
  1. Close the laptop and turn it over so that the base is facing upwards and the spine is away from you. Unscrew the two captive screws with the Phillips #1 and open the compartment. Note that these captive screws cannot be removed from the lid.
    • Close the laptop and turn it over so that the base is facing upwards and the spine is away from you.
    • Unscrew the two captive screws with the Phillips #1 and open the compartment.
    • Note that these captive screws cannot be removed from the lid.
  2. Pull the two tabs away from the RAM so that the RAM will pop out. Gently pull the RAM away from base. Gently pull the RAM away from base.
    • Pull the two tabs away from the RAM so that the RAM will pop out.
    • Gently pull the RAM away from base.
  3. Insert new RAM chips here. Be sure that you are putting it in the right way by comparing the gold connectors to the shape of the slot. Insert new RAM chips here. Be sure that you are putting it in the right way by comparing the gold connectors to the shape of the slot.
    • Insert new RAM chips here. Be sure that you are putting it in the right way by comparing the gold connectors to the shape of the slot.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Nikhitha Byragani
회원 가입일: 2013년 04월 16일
58 평판
안내서 1개 작성함
Cal Poly, Team 4-12, Maness Spring 2013 Cal Poly, Team 4-12, Maness Spring 2013 회원
CPSU-MANESS-S13S4G12
4 회원들
안내서 6개 작성하였습니다
ned solution for my satitillate pro as the fix i need is not listed . my Toshiba is a l875d-s7332 and cu
ls not find the right as the fix given is for and older moldel, can i pls get the right data mailed to my email asasp pls
wendell burgess - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 2,478
