주요 콘텐츠로 건너뛰기
Toshiba Satellite A215-S4757 Battery Replacement
필요한 것
  1. Toshiba Satellite A215-S4757 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before removing anything on your Toshiba Satellite, make sure your computer is turned off, and your power adapter is not plugged in.
  2. Toshiba Satellite A215-S4757 Battery Replacement: 2 단계, 이미지 1/1
    • Turn your Satellite over and locate your battery.
    • Locate the battery clips.
    • With your thumb and pointer fingers slide them outward at the same time, and hold.
  3. Toshiba Satellite A215-S4757 Battery Replacement: 3 단계, 이미지 1/2 Toshiba Satellite A215-S4757 Battery Replacement: 3 단계, 이미지 2/2
    • Gently lift the battery out of its socket until completely removed and release the clips.
    • Your battery is now removed from your computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jacob Brown
회원 가입일: 10/10/16
409 평판
안내서 3개 작성하였습니다
Texas Tech, Team 12-2, Bennett Fall 2016 Texas Tech, Team 12-2, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G2
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 297
