주요 콘텐츠로 건너뛰기
Toshiba Satellite A215-S4757 Display Screen Replacement
필요한 것
  1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: 1 단계, 이미지 1/2 Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: 1 단계, 이미지 2/2
    • First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
    • Remove the four screws underneath each cover and place them somewhere secure.
  2. Toshiba Satellite A215-S4757 Display Screen Replacement: 2 단계, 이미지 1/3 Toshiba Satellite A215-S4757 Display Screen Replacement: 2 단계, 이미지 2/3 Toshiba Satellite A215-S4757 Display Screen Replacement: 2 단계, 이미지 3/3
    • Remove the plastic paneling around the screen, and at the bottom of the display.
    • You may need a plastic opening tool to pry the back crease open.
  3. Toshiba Satellite A215-S4757 Display Screen Replacement: 3 단계, 이미지 1/3 Toshiba Satellite A215-S4757 Display Screen Replacement: 3 단계, 이미지 2/3 Toshiba Satellite A215-S4757 Display Screen Replacement: 3 단계, 이미지 3/3
    • Remove the three screws on each side of the display, and place them somewhere secure.
  4. Toshiba Satellite A215-S4757 Display Screen Replacement: 4 단계, 이미지 1/2 Toshiba Satellite A215-S4757 Display Screen Replacement: 4 단계, 이미지 2/2
    • Gently move the display forward so you can see the back of the component.
  5. Toshiba Satellite A215-S4757 Display Screen Replacement: 5 단계, 이미지 1/3 Toshiba Satellite A215-S4757 Display Screen Replacement: 5 단계, 이미지 2/3 Toshiba Satellite A215-S4757 Display Screen Replacement: 5 단계, 이미지 3/3
    • On the back of the display, there is a wire that is plugged in to the display and secured with tape.
    • Gently lift the tape, leaving it attached to the wire.
    • Pull the wire out of its socket in the display backing.
    • The display is now fully detached!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Brown
회원 가입일: 10/10/16
409 평판
안내서 3개 작성하였습니다
Texas Tech, Team 12-2, Bennett Fall 2016 Texas Tech, Team 12-2, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G2
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 341
