주요 콘텐츠로 건너뛰기
Toshiba Satellite A215-S4757 RAM Replacement
필요한 것
  1. Toshiba Satellite A215-S4757 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Locate the RAM storage space on the back of your Toshiba Satellite.
  2. Toshiba Satellite A215-S4757 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A215-S4757 RAM Replacement: 2 단계, 이미지 2/2
    • Unscrew the two screws holding the plate to the laptop.
    • Gently lift the lid, and remove it form the Satellite.
  3. Toshiba Satellite A215-S4757 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite A215-S4757 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite A215-S4757 RAM Replacement: 3 단계, 이미지 3/3
    • Identify the clips on each side of both RAM components that are holding them in place.
    • To remove each component, simply push each clip gently outward until the component pops upward.
  4. Toshiba Satellite A215-S4757 RAM Replacement: 4 단계, 이미지 1/1
    • Gently pull and remove the RAM component, and repeat for the second component laying underneath the first.
  5. Toshiba Satellite A215-S4757 RAM Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A215-S4757 RAM Replacement: 5 단계, 이미지 2/2
    • Be sure to match each RAM components female insert, with the laptops male insert during reassembly. If you do not reinstall the components correctly your motherboard may fry.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Brown
회원 가입일: 10/10/16
409 평판
안내서 3개 작성하였습니다
Texas Tech, Team 12-2, Bennett Fall 2016 Texas Tech, Team 12-2, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G2
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 335
