필요한 것
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Locate hard drive cover opposite the battery on the lower left corner of the device.
Loosen 2 Phillips 4.2 mm size captive screws from cover.
Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
다른 한 분이 해당 안내서를 완성하였습니다.
