주요 콘텐츠로 건너뛰기
Toshiba Satellite A215-S7425 RAM Replacement
필요한 것
  1. Toshiba Satellite A215-S7425 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 RAM Replacement: 2 단계, 이미지 1/1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 RAM Replacement: 3 단계, 이미지 1/1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 RAM Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A215-S7425 RAM Replacement: 5 단계, 이미지 2/2
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 RAM Replacement: 6 단계, 이미지 1/3 Toshiba Satellite A215-S7425 RAM Replacement: 6 단계, 이미지 2/3 Toshiba Satellite A215-S7425 RAM Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 RAM Replacement: 7 단계, 이미지 1/3 Toshiba Satellite A215-S7425 RAM Replacement: 7 단계, 이미지 2/3 Toshiba Satellite A215-S7425 RAM Replacement: 7 단계, 이미지 3/3
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
결론
Marianne
회원 가입일: 09/08/14
647 평판
안내서 6개 작성하였습니다
Pasco Hernando, Team 5-2, Prince Fall 2014 Pasco Hernando, Team 5-2, Prince Fall 2014 회원
PHSC-PRINCE-F14S5G2
10 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 258
