주요 콘텐츠로 건너뛰기
Toshiba Satellite A215-S7425 Screen Replacement
필요한 것
  1. Toshiba Satellite A215-S7425 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Screen Replacement: 2 단계, 이미지 1/1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Screen Replacement: 3 단계, 이미지 1/1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Screen Replacement, Screen: 4 단계, 이미지 1/2 Toshiba Satellite A215-S7425 Screen Replacement, Screen: 4 단계, 이미지 2/2
    • Use tweezers to remove rubber screw covers on 4 corners of frame around screen.
  5. Toshiba Satellite A215-S7425 Screen Replacement: 5 단계, 이미지 1/1
    • Remove 4 Phillips 5.6 mm screws.
  6. Toshiba Satellite A215-S7425 Screen Replacement: 6 단계, 이미지 1/2 Toshiba Satellite A215-S7425 Screen Replacement: 6 단계, 이미지 2/2
    • Use flat side of spudger to pry the top and sides of the frame around screen.
  7. Toshiba Satellite A215-S7425 Screen Replacement: 7 단계, 이미지 1/2 Toshiba Satellite A215-S7425 Screen Replacement: 7 단계, 이미지 2/2
    • Turn device onto its screen side to access the bottom of hinge portion of the screen and push bottom piece of frame along device hinge until it loosens.
  8. Toshiba Satellite A215-S7425 Screen Replacement: 8 단계, 이미지 1/3 Toshiba Satellite A215-S7425 Screen Replacement: 8 단계, 이미지 2/3 Toshiba Satellite A215-S7425 Screen Replacement: 8 단계, 이미지 3/3
    • Return device to upright position and gently pull frame away from screen.
  9. Toshiba Satellite A215-S7425 Screen Replacement: 9 단계, 이미지 1/1
    • Remove 2 Phillips 5.6 mm screws from below screen.
  10. Toshiba Satellite A215-S7425 Screen Replacement: 10 단계, 이미지 1/2 Toshiba Satellite A215-S7425 Screen Replacement: 10 단계, 이미지 2/2
    • Unplug pink and white monitor cable from bottom of screen.
  11. Toshiba Satellite A215-S7425 Screen Replacement: 11 단계, 이미지 1/1
    • Remove 3 Phillips 3.2 mm screws from each side of the metal case around screen.
  12. Toshiba Satellite A215-S7425 Screen Replacement: 12 단계, 이미지 1/1
    • Pull the screen forward from the top out of the metal frame enough to see the back of the screen.
  13. Toshiba Satellite A215-S7425 Screen Replacement: 13 단계, 이미지 1/3 Toshiba Satellite A215-S7425 Screen Replacement: 13 단계, 이미지 2/3 Toshiba Satellite A215-S7425 Screen Replacement: 13 단계, 이미지 3/3
    • Hold the screen with one hand and gently remove the display cable from the back side of the screen.
    • The display cable is typically glued or taped to the back of the screen. Take care to carefully lift the tape and slowly pull cable.
    • To avoid damaging screen ribbon cable, use caution and be gentle. Do not yank or remove with force. Avoid bending the ribbon cable which can cause the wires inside it to snap and break.
결론
Marianne
회원 가입일: 09/08/14
647 평판
안내서 6개 작성하였습니다
Pasco Hernando, Team 5-2, Prince Fall 2014 Pasco Hernando, Team 5-2, Prince Fall 2014 회원
PHSC-PRINCE-F14S5G2
10 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 424
