주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide teaches you how to replace the hard drive in a Toshiba Satellite A305-S6848 laptop.
부품
지정된 부품이 없습니다.
  1. Remove the 5.8mm Phillip's #0 screw with Phillip's #0 screwdriver while prying plastic covering up with metal spudger. Remove the 5.8mm Phillip's #0 screw with Phillip's #0 screwdriver while prying plastic covering up with metal spudger.
    • Remove the 5.8mm Phillip's #0 screw with Phillip's #0 screwdriver while prying plastic covering up with metal spudger.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Remove plastic covering.
    • Remove plastic covering.
    • Pull up the silver tab to remove the hard drive from the slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joshua E Hong
회원 가입일: 2017년 11월 06일
449 평판
안내서 4개 작성하였습니다
Baylor, Team S8-G1, Johnson Fall 2017 Baylor, Team S8-G1, Johnson Fall 2017 회원
BU-JOHNSON-F17S8G1
2 회원들
안내서 4개 작성하였습니다
Note: There are two hard drives in this machine. One has a single screw holding it in place within the compartment, and is very straightforward. The other has two screws. After removing the latter, the drive compartment pulls out, sliding over the now empty screw holes.
Kim McCoy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 361
