주요 콘텐츠로 건너뛰기
Toshiba Satellite A305-S6848 Keyboard Replacement
필요한 것
  1. Toshiba Satellite A305-S6848 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 Keyboard Replacement: 2 단계, 이미지 1/1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 Keyboard Replacement: 3 단계, 이미지 1/1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • The keyboard is held in by a locking strip between the screen and the keyboard.
  5. Toshiba Satellite A305-S6848 Keyboard Replacement: 5 단계, 이미지 1/1
    • Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
  6. Toshiba Satellite A305-S6848 Keyboard Replacement: 6 단계, 이미지 1/1
    • Use your hand to take out locking strip from the right portion that was pried out.
  7. Toshiba Satellite A305-S6848 Keyboard Replacement: 7 단계, 이미지 1/2 Toshiba Satellite A305-S6848 Keyboard Replacement: 7 단계, 이미지 2/2
    • Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
  8. Toshiba Satellite A305-S6848 Keyboard Replacement: 8 단계, 이미지 1/2 Toshiba Satellite A305-S6848 Keyboard Replacement: 8 단계, 이미지 2/2
    • Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
    • Disconnect the keyboard by flipping the locking clip upwards.
결론
Joshua E Hong
회원 가입일: 11/06/17
449 평판
안내서 4개 작성하였습니다
Baylor, Team S8-G1, Johnson Fall 2017 Baylor, Team S8-G1, Johnson Fall 2017 회원
BU-JOHNSON-F17S8G1
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 561
