주요 콘텐츠로 건너뛰기
Toshiba Satellite A305-S6848 LCD Screen Replacement
필요한 것
  1. Toshiba Satellite A305-S6848 LCD Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1/2 Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 2/2
    • Remove the 6 rubber tabs on the housing using the metal spudger.
  5. Toshiba Satellite A305-S6848 LCD Screen Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A305-S6848 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Remove the six 5.8 mm screws using the Phillip's #0 screwdriver.
  6. Toshiba Satellite A305-S6848 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Pry out plastic housing on all sides.
  7. Toshiba Satellite A305-S6848 LCD Screen Replacement: 7 단계, 이미지 1/2 Toshiba Satellite A305-S6848 LCD Screen Replacement: 7 단계, 이미지 2/2
    • Pry out the bottom left and right locking pieces of the plastic housing with the metal spudger.
  8. Toshiba Satellite A305-S6848 LCD Screen Replacement: 8 단계, 이미지 1/2 Toshiba Satellite A305-S6848 LCD Screen Replacement: 8 단계, 이미지 2/2
    • Remove the four 5.8 mm screws using the Phillip's #0 screwdriver.
  9. Toshiba Satellite A305-S6848 LCD Screen Replacement: 9 단계, 이미지 1/1
    • Remove the eight 6.5 mm screws on the left and right sides of the screen using the Phillip's #0 screwdriver.
  10. Toshiba Satellite A305-S6848 LCD Screen Replacement: 10 단계, 이미지 1/2 Toshiba Satellite A305-S6848 LCD Screen Replacement: 10 단계, 이미지 2/2
    • Pull the screen down.
    • Pull off tape and take our video connector.
  11. Toshiba Satellite A305-S6848 LCD Screen Replacement: 11 단계, 이미지 1/1
    • Remove cold cathode fluorescent light bulb connector.
결론
Joshua E Hong
회원 가입일: 11/06/17
449 평판
안내서 4개 작성하였습니다
Baylor, Team S8-G1, Johnson Fall 2017 Baylor, Team S8-G1, Johnson Fall 2017 회원
BU-JOHNSON-F17S8G1
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 523
