주요 콘텐츠로 건너뛰기
Toshiba Satellite A505 series Battery Replacement
  1. Toshiba Satellite A505 series Battery Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A505 series Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the system over and locate the locking switches near the battery.
    • This switch is not spring-loaded. Slide it away from the battery to unlock.
    • This switch IS spring-loaded and will have to be held to release the battery. It slides in the opposite direction of the first switch.
    • The example here shows an after-market high-capacity battery. The procedure is the same, regardless.
결론
Follow this procedure in reverse to install the (new) battery. Note that the second switch will engage automatically upon install. The first switch will not and must be locked manually once the battery is in place.
다른 5명이 해당 안내서를 완성하였습니다.
Jerry F Nerviano
회원 가입일: 11/18/10
2,125 평판
안내서 1개 작성함
Jerry's Computer Service Jerry's Computer Service 회원
Business
1 회원
안내서 3개 작성하였습니다
댓글 4개
I have a Toshiba statellite click W35Dt-A3300 window 8.1
How do I take and put new battery in ?
eddiecabral32 - 답글
Have you seen the Toshiba Satellite Click guides? This should be the battery guide you need: Toshiba Satellite Click Tablet Battery Replacement.
Sam Goldheart -
I have a Toshiba A356-S69253 and the battery after a long charge reads 7 - 13 % Charge. On rare occasion I see 97% but within a minute or two the computer shuts down. When I restart the charge is down to 3%. I am having uncontrolled shut down and other problem and suspect a battery problem
The Battery is built in. Can I change the battery? How much is a battery? Can someone else change the battery? How much $? The laptop is pretty old, is it worth trying to fix?
buschwa@aol.com 7/2/2017
buschwa - 답글
Hvordan tager jeg batteri ud af en Toshiba Satellite L50D-A-10D
Birthe Kirkgaard - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 4,255
