주요 콘텐츠로 건너뛰기
Toshiba Satellite A65-S126 Optical Drive Replacement
필요한 것
  1. Toshiba Satellite A65-S126 Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Optical Drive Replacement, Upper Assembly: 3 단계, 이미지 1개 중 1개
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite A65-S126 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Optical Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Optical Drive Replacement, Optical Drive: 9 단계, 이미지 1개 중 1개
    • Orient the bottom assembly as displayed.
  10. Toshiba Satellite A65-S126 Optical Drive Replacement: 10 단계, 이미지 2개 중 1개 Toshiba Satellite A65-S126 Optical Drive Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the two 3 mm Phillips #00 screws.
  11. Toshiba Satellite A65-S126 Optical Drive Replacement: 11 단계, 이미지 1개 중 1개
    • Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
결론
작성자
5다른 기여자 명과 함께
Geoff Wacker
회원 가입일: 09/30/13
92,071 평판
안내서 89개를 작성함
1가이드 댓글
Or, simply remove the screw (the center one in this photo) from the bottom case that holds the bracket in and pull the drive out.
J Howard Markley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 1,151
