주요 콘텐츠로 건너뛰기
Toshiba Satellite A65-S126 Optical Drive Replacement
필요한 것
  1. Toshiba Satellite A65-S126 Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Optical Drive Replacement, Upper Assembly: 3 단계, 이미지 1/1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Optical Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A65-S126 Optical Drive Replacement: 5 단계, 이미지 2/2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Optical Drive Replacement: 6 단계, 이미지 1/1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Optical Drive Replacement: 7 단계, 이미지 1/1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Optical Drive Replacement: 8 단계, 이미지 1/1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Optical Drive Replacement, Optical Drive: 9 단계, 이미지 1/1
    • Orient the bottom assembly as displayed.
  10. Toshiba Satellite A65-S126 Optical Drive Replacement: 10 단계, 이미지 1/2 Toshiba Satellite A65-S126 Optical Drive Replacement: 10 단계, 이미지 2/2
    • Remove the two 3 mm Phillips #00 screws.
  11. Toshiba Satellite A65-S126 Optical Drive Replacement: 11 단계, 이미지 1/1
    • Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
결론
Geoff Wacker
회원 가입일: 09/30/13
89,964 평판
안내서 89개 작성하였습니다
댓글 한 개
Or, simply remove the screw (the center one in this photo) from the bottom case that holds the bracket in and pull the drive out.
J Howard Markley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 14
전체 시간: 987
