주요 콘텐츠로 건너뛰기
Toshiba Satellite A660-ST3NX2X Hard Drive Replacement
필요한 것
  1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 2 단계, 이미지 2/2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 3 단계, 이미지 1/3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 3 단계, 이미지 2/3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 3 단계, 이미지 3/3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Unplug all devices from your computer and power down the device completely.
    • Flip the computer over so the screen is facing down.
    • In the image, the hard drive will appear to be in the top right corner where the box indicates.
  5. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 5 단계, 이미지 2/2
    • Use a J00 bit to unscrew the single 4mm screw that holds the hard drive cover in place.
  6. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the cover that holds the hard drive in place.
    • Remove the hard drive.
    • This computer contains no hard drive, therefore we are unable to show the physical removal of it.
결론
Cassie Pickett
회원 가입일: 03/20/17
201 평판
안내서 2개 작성하였습니다
Texas Tech, Team S8-G1, Bennett Spring 2017 Texas Tech, Team S8-G1, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G1
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 495
