주요 콘텐츠로 건너뛰기
Toshiba Satellite A665-S5170 Battery Replacement
필요한 것
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A665-S5170 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: 2 단계, 이미지 1/1
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: 3 단계, 이미지 1/3 Toshiba Satellite A665-S5170 Battery Replacement: 3 단계, 이미지 2/3 Toshiba Satellite A665-S5170 Battery Replacement: 3 단계, 이미지 3/3
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chelsea Teague
회원 가입일: 10/30/16
385 평판
안내서 2개 작성하였습니다
Baylor, Team 4-5, Williams Fall 2016 Baylor, Team 4-5, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 20
전체 시간: 1,174
