주요 콘텐츠로 건너뛰기
Toshiba Satellite A665-S5170 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite A665-S5170 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn the computer upside down so that the bottom of the laptop is facing up.
    • Position the laptop so that you are able to read the words printed on the labels on the bottom of the laptop from left to right, and so that the laptop's hard drive panel is in the upper right-hand corner of the bottom of the computer.
    • Using a Phillip’s head 0 screwdriver, remove the 2mm Phillips head screw on the right side of the cover of the hard drive panel by rotating it counter-clockwise.
  2. Toshiba Satellite A665-S5170 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A665-S5170 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Insert something thin, such as your nail or a credit card, into the slot on the right side of the cover of the hard drive panel.
    • Pull your finger up to pop off the cover of the hard drive panel.
  3. Toshiba Satellite A665-S5170 Hard Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite A665-S5170 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Gently push down on the hard drive with your hand.
    • Still pressing down on the hard drive, move your hand to the right in order to slide the hard drive to the right and to disconnect it from the computer.
  4. Toshiba Satellite A665-S5170 Hard Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite A665-S5170 Hard Drive Replacement: 4 단계, 이미지 2/2
    • To pull out the hard drive, pinch the plastic tab attached to the right of the hard drive with your thumb and index finger.
    • Gently lift the hard drive from the panel by pulling up on the plastic tab.
결론
Chelsea Teague
회원 가입일: 10/30/16
385 평판
안내서 2개 작성하였습니다
Baylor, Team 4-5, Williams Fall 2016 Baylor, Team 4-5, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 19
전체 시간: 1,857
