주요 콘텐츠로 건너뛰기
Toshiba Satellite A75-S226 Keyboard Replacement
필요한 것
  1. Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
    • It may be helpful to first pry at the rear of the hinge covers (not shown) to release them. Then Insert the plastic opening tool underneath the top panel's sides and then front edge.
  2. Toshiba Satellite A75-S226 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A75-S226 Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
  3. Toshiba Satellite A75-S226 Keyboard Replacement: 3 단계, 이미지 1/3 Toshiba Satellite A75-S226 Keyboard Replacement: 3 단계, 이미지 2/3 Toshiba Satellite A75-S226 Keyboard Replacement: 3 단계, 이미지 3/3
    • Remove the two 3.67 mm screws from the top corners of the keyboard.
  4. Toshiba Satellite A75-S226 Keyboard Replacement: 4 단계, 이미지 1/1
    • Use fingers to lift up the keyboard from the top.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  5. Toshiba Satellite A75-S226 Keyboard Replacement: 5 단계, 이미지 1/3 Toshiba Satellite A75-S226 Keyboard Replacement: 5 단계, 이미지 2/3 Toshiba Satellite A75-S226 Keyboard Replacement: 5 단계, 이미지 3/3
    • Remove the cable connecting the keyboard with the motherboard.
    • Be aware of the locking tabs on each side of the ribbon-cable connector—they slide back about 2mm to free the cable.
    • Lift up and remove the keyboard.
결론
Garrett Gudgel
회원 가입일: 10/05/10
763 평판
안내서 13개 작성하였습니다
Cal Poly, Team 4-43, Amido Fall 2010 Cal Poly, Team 4-43, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G43
5 회원들
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 4,250
