이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Make sure battery-lock is in the unlock position.
Slide button to the left.
Remove the optical drive cover.
A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
Using the inset divot, push the optical drive out of the laptop to remove.
Push the bottom left corner of the CD Drive until the drive protrudes from the case.
When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
Remove the 5.64 mm screw from the bottom of the crossing bar.
Remove the crossing bar.
Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
Remove the cable connecting the keyboard with the motherboard.
Lift up and remove the keyboard.
Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
Then remove the fourteen 8.6 mm screws from the bottom of the case.
Use the screwdriver to remove six 8.6 mm screws from the top of the case.
Use the plastic opening tool to remove the two speaker wire connectors and the trackpad connector from the motherboard.
With the plastic opening tool, pry around the entire laptop to separate the upper case.
다른 한 분이 해당 안내서를 완성하였습니다.
