주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. Remove the 5.75 mm screw from the cover panel. Turn the laptop over with the screen facing down.
    • Remove the 5.75 mm screw from the cover panel.
    • Turn the laptop over with the screen facing down.
  2. Lift up the cover panel using a plastic opening tool.
    • Lift up the cover panel using a plastic opening tool.
  3. Remove the 5.64 mm screw from the bottom of the crossing bar. Remove the crossing bar.
    • Remove the 5.64 mm screw from the bottom of the crossing bar.
    • Remove the crossing bar.
  4. Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card. Note that the black wire is connected to the port that is labeled main.
    • Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
    • Note that the black wire is connected to the port that is labeled main.
  5. Use fingers to push the clips away from memory card. Use fingers to push the clips away from memory card.
    • Use fingers to push the clips away from memory card.
  6. Use fingers to remove the Wi-Fi card.
    • Use fingers to remove the Wi-Fi card.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Garrett Gudgel
회원 가입일: 2010년 10월 05일
751 평판
안내서 13개 작성하였습니다
Cal Poly, Team 4-43, Amido Fall 2010 Cal Poly, Team 4-43, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G43
5 회원들
안내서 13개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,088
