주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Power off the laptop.
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right.
    • This tab will latch into place.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide the tab shown to the left and remain holding it.
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Loosen this 5 mm Phillips #0 screw found in the center of the lower case. The screw will not come out completely, it will stay connected to the center plate.
    • Loosen this 5 mm Phillips #0 screw found in the center of the lower case.
    • The screw will not come out completely, it will stay connected to the center plate.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the center plate by lifting it and sliding it to the right.
    • Remove the center plate by lifting it and sliding it to the right.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that the screw is loose before attempting again.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
    • The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Shravani Kakarla
회원 가입일: 2014년 03월 11일
107 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-5, Cichon Spring 2014 UMass Dartmouth, Team 1-5, Cichon Spring 2014 회원
UMASSD-CICHON-S14S1G5
4 회원들
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 439
