주요 콘텐츠로 건너뛰기
Toshiba Satellite A85-S107 15" Disc Drive Replacement
필요한 것
  1. Toshiba Satellite A85-S107 15" Disc Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Disc Drive Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Disc Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite A85-S107 15" Disc Drive Replacement: 3 단계, 이미지 2/2
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Disc Drive Replacement, Disc Drive: 4 단계, 이미지 1/2 Toshiba Satellite A85-S107 15" Disc Drive Replacement, Disc Drive: 4 단계, 이미지 2/2
    • Flip the laptop over and orient it so that the battery faces away from you.
    • Remove the 5mm Phillips #0 screw on the bottom case.
  5. Toshiba Satellite A85-S107 15" Disc Drive Replacement: 5 단계, 이미지 1/3 Toshiba Satellite A85-S107 15" Disc Drive Replacement: 5 단계, 이미지 2/3 Toshiba Satellite A85-S107 15" Disc Drive Replacement: 5 단계, 이미지 3/3
    • Insert the plastic opening tool into the gap between the disk drive and the laptop and pop out the disk drive.
    • Slid the disc drive out of its slot on the left side of the computer. It should slide out easily.
결론
Alana
회원 가입일: 04/14/13
96 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-38, Amido Spring 2013 Cal Poly, Team 10-38, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G38
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 546
