주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Use this guide to replace or install the hard drive in your Toshiba laptop.
  1. Power off the laptop.
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Slide the tab shown to the left and remain holding it. This tab does not lock into place like in the first step.
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Nintendo Switch 수리 키트
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Flip the computer around so the battery is facing away from you.
    • Flip the computer around so the battery is facing away from you.
  6. Locate 5mm Philips #0 screw on hard drive cover. Remove these two 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
    • Locate 5mm Philips #0 screw on hard drive cover.
    • Remove these two 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
  7. Insert the plastic opening tool into the tab shown and lift up to remove the lower left plate. If the hard drive panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    • Insert the plastic opening tool into the tab shown and lift up to remove the lower left plate.
    • If the hard drive panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  8. Use plastic opening tool to lift hard drive out of case.
    • Use plastic opening tool to lift hard drive out of case.
    • Lift the left side of the hard drive and slide it out towards the left.
    • We do not have all the required parts for this guide.
결론
Travis
회원 가입일: 2013년 04월 13일
31 평판
안내서 5개 작성하였습니다
Cal Poly, Team 10-38, Amido Spring 2013 Cal Poly, Team 10-38, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G38
4 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 732
