주요 콘텐츠로 건너뛰기
Toshiba Satellite A85-S107 15" RAM Replacement
필요한 것
  1. Toshiba Satellite A85-S107 15" RAM Replacement, Back Panel: 1 단계, 이미지 1/1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" RAM Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right.
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" RAM Replacement: 3 단계, 이미지 1/1
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite A85-S107 15" RAM Replacement: 4 단계, 이미지 2/2
    • Loosen this 5 mm Phillips #0 screw found in the center of the lower case.
    • The screw will not come out completely, it will stay connected to the center plate.
  5. Toshiba Satellite A85-S107 15" RAM Replacement: 5 단계, 이미지 1/1
    • Remove the center plate by lifting it and sliding it to the right.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that the screw is loose before attempting again.
  6. Toshiba Satellite A85-S107 15" RAM Replacement: 6 단계, 이미지 1/1
    • The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
  7. Toshiba Satellite A85-S107 15" RAM Replacement, RAM: 7 단계, 이미지 1/1
    • Push the two white tabs away from the RAM. The left side of the RAM should pop out of its holder.
  8. Toshiba Satellite A85-S107 15" RAM Replacement: 8 단계, 이미지 1/1
    • Pull the RAM out of the dock by lifting it from the left side and sliding it towards the left.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Travis
회원 가입일: 04/13/13
31 평판
안내서 5개 작성하였습니다
Cal Poly, Team 10-38, Amido Spring 2013 Cal Poly, Team 10-38, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G38
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 22
전체 시간: 1,070
