이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
Unlock the battery by sliding the tab shown to the right.
This tab will latch into place.
Slide the tab shown to the left and remain holding it.
Place your thumb on the grips of the battery as shown.
While holding onto the grips, pull the battery towards you and away from the laptop.
Loosen this 5 mm Phillips #0 screw found in the center of the lower case.
The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
Push the two white tabs away from the RAM. The left side of the RAM should pop out of its holder.
Pull the RAM out of the dock by lifting it from the left side and sliding it towards the left.
다른 2명이 해당 안내서를 완성하였습니다.
