이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
Unlock the battery by sliding the tab shown to the right.
This tab will latch into place.
Slide the tab shown to the left and remain holding it.
Place your thumb on the grips of the battery as shown.
While holding onto the grips, pull the battery towards you and away from the laptop.
Loosen this 5 mm Phillips #0 screw found in the center of the lower case.
The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
Carefully pull the white auxiliary wire out of its socket on the wireless card.
Now repeat this step with the black auxiliary wire.
Push the two black tabs, located on the sides of the card, away from the card.
The right side of the wireless card should now pop out of its holder.
Pull the wireless card out by lifting it from the dock and sliding it towards the right.
