주요 콘텐츠로 건너뛰기
Toshiba Satellite C50D-A Fan Replacement
필요한 것
  1. Toshiba Satellite C50D-A Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A Fan Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C50D-A Fan Replacement: 2 단계, 이미지 2/2
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A Fan Replacement, Lower Case: 3 단계, 이미지 1/2 Toshiba Satellite C50D-A Fan Replacement, Lower Case: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A Fan Replacement: 4 단계, 이미지 1/1
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A Fan Replacement: 5 단계, 이미지 1/1
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A Fan Replacement: 6 단계, 이미지 1/3 Toshiba Satellite C50D-A Fan Replacement: 6 단계, 이미지 2/3 Toshiba Satellite C50D-A Fan Replacement: 6 단계, 이미지 3/3
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A Fan Replacement, Fan: 7 단계, 이미지 1/3 Toshiba Satellite C50D-A Fan Replacement, Fan: 7 단계, 이미지 2/3 Toshiba Satellite C50D-A Fan Replacement, Fan: 7 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the one 1.5mm screw.
  8. Toshiba Satellite C50D-A Fan Replacement: 8 단계, 이미지 1/1
    • Lift the fan up and blow compressed air or replace with a new one.
    • Blow compressed air into the spirals in the middle of the fan.
결론
Amber van Solingen
회원 가입일: 01/29/18
678 평판
안내서 6개 작성하였습니다
University of Alabama, Team S3-G11, Bedsole Spring 2018 University of Alabama, Team S3-G11, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S3G11
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 12
전체 시간: 1,187
