주요 콘텐츠로 건너뛰기
Toshiba Satellite C50D-A Optical Drive Replacement
필요한 것
  1. Toshiba Satellite C50D-A Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite C50D-A Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A Optical Drive Replacement, Lower Case: 3 단계, 이미지 2개 중 1개 Toshiba Satellite C50D-A Optical Drive Replacement, Lower Case: 3 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A Optical Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A Optical Drive Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Satellite C50D-A Optical Drive Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Satellite C50D-A Optical Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A Optical Drive Replacement, Optical Drive: 7 단계, 이미지 1개 중 1개
    • Locate the opticaldrive and find where it is slotted into the motherboard.
    • Be careful not to break the attachment site.
  8. Toshiba Satellite C50D-A Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Gently lift up the optical drive at a slight angle, and pull it towards you to remove it.
결론
작성자
2다른 기여자 명과 함께
Amber van Solingen
회원 가입일: 01/29/18
710 평판
안내서 6개를 작성함
댓글 한 개
This is an awful guide - it does not tell you that there are another 6 or more screws under the keyboard - this is bad.
Books2Africa Tech Team - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 928
