주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement
필요한 것
  1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: 1 단계, 이미지 3개 중 1개 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: 1 단계, 이미지 3개 중 2개 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: 1 단계, 이미지 3개 중 3개
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  2. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  3. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  4. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: 4 단계, 이미지 2개 중 1개 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: 4 단계, 이미지 2개 중 2개
    • Unscrew all 15 of the screws in the back cover of the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  5. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the two silver screws attaching the fan to the case.
    • Unplug the power connector for the fan.
    • Pull the fan up out of the slot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rei Rutkowski
회원 가입일: 11/26/18
184 평판
안내서 2개를 작성함
IUPUI, Team S8-G8, Wilson Fall 2018 IUPUI, Team S8-G8, Wilson Fall 2018 회원
IUPUI-WILSON-F18S8G8
4 회원들
안내서 6개를 작성함
댓글 한 개
The one I disassembled didn’t have a screw under the battery bay, but did have one under the HDD bay, just as described by a comment in the charge port replacement guide.
Luis Alejandro Araúz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 1,055
