주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5100 Charging Port Jack Replacement
필요한 것
  1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: 3 단계, 이미지 3개 중 1개 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: 3 단계, 이미지 3개 중 2개 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: 3 단계, 이미지 3개 중 3개
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the disc drive from the device.
  6. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: 6 단계, 이미지 3개 중 1개 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: 6 단계, 이미지 3개 중 2개 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: 6 단계, 이미지 3개 중 3개
    • Place the laptop with the bottom facing up.
  7. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 7 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  8. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 8 단계, 이미지 2개 중 2개
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  9. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Charging Port Jack: 9 단계, 이미지 1개 중 1개
    • Unscrew all 15 screws that attach the back cover to the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  10. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 10 단계, 이미지 3개 중 1개 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 10 단계, 이미지 3개 중 2개 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 10 단계, 이미지 3개 중 3개
    • Locate the charging jack. Then carefully pull straight up.
    • Unplug the connector by pulling it towards the charging port side of the case, then carefully guide the wires away from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Rei Rutkowski
회원 가입일: 11/26/18
184 평판
안내서 2개를 작성함
IUPUI, Team S8-G8, Wilson Fall 2018 IUPUI, Team S8-G8, Wilson Fall 2018 회원
IUPUI-WILSON-F18S8G8
4 회원들
안내서 6개를 작성함
1가이드 댓글
Hi. Correction on Step 9. Aside from the 15 black screws, I had to unscrew one silver screw. It sits right under the HDD.
Everything else was perfectly described.
Isidro B. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 22
전체 시간: 1,861
