주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5100 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C55-A5100 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  5. Toshiba Satellite C55-A5100 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55-A5100 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
결론
Walker Tortorigi
회원 가입일: 01/29/18
495 평판
안내서 4개 작성하였습니다
University of Alabama, Team S3-G10, Bedsole Spring 2018 University of Alabama, Team S3-G10, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S3G10
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 6
30일 전: 19
전체 시간: 909
