주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5100 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C55-A5100 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached to the keyboard.
  4. Toshiba Satellite C55-A5100 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Looking at the keyboard, locate the eight clips that hold it in place.
  5. Toshiba Satellite C55-A5100 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite C55-A5100 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to slide the clips back, releasing the keyboard.
    • As you release the clips, use the plastic opening tool to lift keyboard above the clips.
  6. Toshiba Satellite C55-A5100 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Once the keyboard is released from the clips you should be able to lift it up, exposing the wire connecting it to the laptop.
    • The keyboard will slide out of the clips on the top.
  7. Toshiba Satellite C55-A5100 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Using your fingers, slowly pull the wire out of its connection.
    • The keyboard is now disconnected.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walker Tortorigi
회원 가입일: 01/29/18
495 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 1,020
