주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5140 Battery Replacement
  1. Toshiba Satellite C55-A5140 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the device is unplugged, completely off, and not warm to the touch.
    • Check for any visible battery defects such as bulges, bends or cracking as they could be signs of a leaking or deformed battery.
    • Do not handle a deformed battery. Deformed batteries can cause burns and exposure to harmful chemicals.
    • Flip device over and locate two switches on the back of the device.
  2. Toshiba Satellite C55-A5140 Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-A5140 Battery Replacement: 2 단계, 이미지 2/2
    • Slide switch 1 towards the unlock symbol on the device (switch should click into place).
    • Slide switch 2 towards the unlocked symbol on the device.
    • While holding switch 2 in the unlocked position, use the notch located at the top of the battery to pull battery out and away from the device.
    • Switch 2 does not lock into place and will need to be held in unlocked position.
  3. Toshiba Satellite C55-A5140 Battery Replacement: 3 단계, 이미지 1/1
    • Pull battery free from device and release switch 2.
결론
To reassemble your device, follow these instructions in reverse order. When inserting new battery make sure to align bottom of battery with the slot first before inserting battery
Cameron Chapman
회원 가입일: 09/27/17
533 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 342
