소개
A common problem with laptop computers is that the CD drive can stop working. Whether that is from physical damage, defects, or a malfunction of the CD drive. When the CD drive stops working properly it can be replaced relatively easy.
필요한 것
Make sure the device is unplugged, completely off, and not warm to the touch.
Check for any visible battery defects such as bulges, bends or cracking as they could be signs of a leaking or deformed battery.
Flip device over and locate two switches on the back of the device.
Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
Flip the device over so you see the bottom, and loosen the 5mm PH#1 screw on the L shaped access panel.
